[GRASS-user] Re: Error: Grass and Grass Plugin in QGIS
Markus Neteler
neteler at osgeo.org
Thu Sep 15 02:58:44 EDT 2011
On Thu, Sep 15, 2011 at 7:43 AM, Solimyr <giannicristian at msn.com> wrote:
> I think yes!When I have created the location and the mapset, instead when put
> myself the coordinates (e.g. WGS84 UTM Zone 30) I have set that using the
> GeoTiff image!So when I open the same GeoTiff image, I get the image with
> red boundaries around that!!
> Is it sounds correct?Or I need to set something else?
Essentially you need to set the region to the map. This is done with
g.region rast=your_raster_map [-p]
Markus
