[GRASS-user] problem with r.li.mps
ahmadou dicko
dicko.ahmadou at gmail.com
Mon Sep 19 05:24:20 EDT 2011
Hi
could you describe the method? is it just an extraction of
> category 2 from landcover_1m?
Not exactly, is an extraction of the category 5 (forest) from the
landclass96 image
r.mapcalc 'forest1996 = if (landclass96 == 5, 1, null())'
But the behaviour doesn't change if you choose the category 5 of the
landcover_1m
[If it is ok with Markus & Helena perhaps we could add it as the
> example on the r.li.mps help page]
It will be great...
Thank's for reporting this as a bug
Ahmadou
2011/9/19 Hamish <hamish_b at yahoo.com>
> ahmadou dicko wrote:
> > I tried to reproduce the r.li exemple from the GRASS book
> > and have a problem with r.li.mps, i tried with the 6.4.2svn
> > version and i upgrade to 6.5svn but i still have the same
> > issue.
> > (i skip the part of the code where forest1996 is build).
> > I don't know if this matter but i use kubuntu natty. And
> > ask me for more info if necessary.
> > so forest1996 is my raster map of forest category (only).
> > r.li.mps --overwrite map=forest1996 conf=movwindow7 output=forest_p_mps7
> > *** glibc detected *** r.li.mps: double free or corruption
> > (fasttop): 0x0000000001e17bf0 ***
> > r.li.mps(calculate+0x58e)[0x4017fe]
> > r.li.mps(meanPatchSize+0x148)[0x402cc8]
> > /usr/local/grass-6.5.svn/lib/libgrass_rli.so(worker+0x2fa)
> > 1314471 /lib/x86_64-linux-gnu/libm-
> > 2.13.so*** glibc detected *** r.li.mps: free(): invalid next
> > size (fast): 0x0000000001e181e0 ***
> Hamish
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? enlev?e...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110919/64888206/attachment.html
