[GRASS-user] RE: r.texture error
Solimyr giannicristian at msn.com
Mon Sep 19 16:20:05 EDT 2011
Thanks for the answer!!!Can you link to me the manual url please?
I'm not understand why I must do that (rescale) because if I change the kernel window and the step I get different value from 300 (but all over 255).
If I do this rescale and I compare the result with the ENVI tool or the ArcMap tool, I get the same results or this rescale will change the result?
Thanks in advance for the answer!
Solimyr
Date: Mon, 19 Sep 2011 12:43:09 -0700
To: giannicristian at msn.com
Subject: Re: r.texture error
	On Mon, Sep 19, 2011 at 10:22 AM, Solimyr <[hidden email]> wrote:
> Hi,
> I'm running r.texture over an image but I get the following error:
> Reading raster map...
> ERROR: Too many categories (found: 300, max: 255). Try to rescale or
> reclassify the map
> What is mean?!!??What are the categories?How can I reduce that?
Like this:
r.rescale input=input output=output to=0,255
r.texture ...
> No idea what this mean!!
I have improved the manual now to better explain this issue.
Markus
grass-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/grass-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1803224.n2.nabble.com/r-texture-error-tp6807585p6809826.html
		To unsubscribe from r.texture error, click here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-texture-error-tp6807585p6809934.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110919/6920ea8e/attachment.html
