[GRASS-user] Removing small areas using v.clean
Pierre Roudier
pierre.roudier at gmail.com
Wed Sep 21 23:26:20 EDT 2011
BTW I confirm I got similar problems with the 6.4 series,
Pierre
2011/9/22 Pierre Roudier <pierre.roudier at gmail.com>:
> Thanks Markus,
> Here's an archive containing the input vector layer, along with
> v.clean output:
> https://df.bestgrid.org/quickshare/fb0bb3af778c8a03/vectors.tar.gz
> Here's the result of v.info -h on the output:
> COMMAND: r.to.vect input="c_means" output="foo" feature="area"
> GISDBASE: /data/GRASSDATA
> LOCATION: NZTM2000 MAPSET: BH USER: roudierp DATE: Thu Sep 15 17:29:53 2011
> COMMAND: v.clean input="foo" layer="1"
> type="point,line,boundary,centroid,area,face,kernel" output="bar"
> tool="rmar
> ea" thresh=900
> LOCATION: NZTM2000 MAPSET: BH USER: roudierp DATE: Thu Sep 15 17:31:45 2011
> [Raster MASK present]
> Cheers,
> Pierre
> 2011/9/21 Markus Metz <markus.metz.giswork at googlemail.com>:
>> On Wed, Sep 21, 2011 at 12:51 AM, Pierre Roudier
>> <pierre.roudier at gmail.com> wrote:
>>> Markus,
>>> Sorry for this late reply as I was away from keyboard the last few days,
>>> I encountered this problem while testing the latest grass_svn (grass
>>> 7). I can give it a shot using a stable version if you want,
>> You can try, but I would be surprised if the result is any different.
>> Can you make the vector available for testing, or can you reproduce
>> this with a vector of the sample datasets?
>> Markus M
>>> 2011/9/17 Markus Metz <markus.metz.giswork at googlemail.com>:
>>>> On Fri, Sep 16, 2011 at 6:28 AM, Pierre Roudier
>>>>> Dear list,
>>>>> I got a problem as I'm trying to remove small areas of a vector layer
>>>>> using v.clean with the rmarea tool: some of these small areas that are
>>>>> on the boundary of the layer are getting erased rather than being
>>>>> merged with the closest polygon.
>>>>> Is that an expected behaviour?
>>>> No, they should always be merged with a neighbouring area along the
>>>> shared boundary. Areas are supposed to be erased only if they are
>>>> isolated, i.e. do not share a boundary with another area. What GRASS
>>>> version are you using? There was a bug which was fixed 2 years ago.
>>>> Markus M
>>> Scientist
>>> Landcare Research, New Zealand
> Scientist
Scientist
