Carlos Grohmann wrote: > Well, I managed to get it working, but only compiling as 32bit. As 64bit I > got errors in wximgview That's only a problem if you need wximgview. The same functionality is available via wxpyimgview. Or maybe d.mon has made this redundant? -- Glynn Clements <glynn at gclements.plus.com>
