[GRASS-user] help building GRASS 7 svn on MacOSX Lion
William Kyngesburye
woklist at kyngchaos.com
Sat Sep 24 11:45:17 EDT 2011
Ah, another holdout based on compiled code linked to wx libraries, instead of the current ctypes way. If, as Glynn says, there is a ctypes replacement, use it instead and compile 64bits and don't worry about the wximgview error.
Glynn, if wxpyimgview is fully functional (or d.mon works the same), is there a a reason to keep wximgview around? Maybe at least disable its compilation?
On Sep 24, 2011, at 8:46 AM, Glynn Clements wrote:
> Carlos Grohmann wrote:
>> Well, I managed to get it working, but only compiling as 32bit. As 64bit I
>> got errors in wximgview
> That's only a problem if you need wximgview. The same functionality is
> available via wxpyimgview. Or maybe d.mon has made this redundant?
> Glynn Clements <glynn at gclements.plus.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
