[GRASS-user] What does agnps stand for in r.fill.dir
Rainer M Krug
r.m.krug at gmail.com
Fri Sep 30 14:25:15 EDT 2011
On Fri, Sep 30, 2011 at 3:48 PM, ahmadou dicko <dicko.ahmadou at gmail.com>wrote:
> Hi Rainer,
> I think that AGNPS stand for AGricultural Non-Point Source Pollution
> Model, more info at : http://go.usa.gov/KFO
I found that as well - but the naming does not make that much sense, as
agnps stands for a format of the flow direction? I assume, the coding of the
direction is in line with what the AGNPS model needs.
Cheers,
Rainer
> Ahmadou
> 2011/9/30 Rainer M Krug <r.m.krug at gmail.com>
>> Hi
>> I can specify that the Output aspect direction format is in the agnps
>> format. I understand the format, d=but I am wondering: what does agnps
>> actually stand for?
>> Cheers,
>> Rainer
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel : +33 - (0)9 53 10 27 44
>> Cell: +33 - (0)6 85 62 59 98
>> Fax (F): +33 - (0)9 58 10 27 44
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> email: Rainer at krugs.de
>> Skype: RMkrug
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
South Africa
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110930/6954ce44/attachment.html
