[GRASS-user] r.stream.extract Syntax Problem
Rich Shepard rshepard at appl-ecosys.com
Fri Apr 6 13:32:55 EDT 2012
On Fri, 6 Apr 2012, Rich Shepard wrote:
> GRASS 6.5.svn :~/grassdata > r.stream.extract
> elev=dem10m.avg accum=dem10m.acc.weighted thresh=1000
> stream_rast=dem10m.lm.streams
> Load input maps and get start points...
> ERROR: Accumulation map does not match elevation map!
   Is it practical to build grass with symbols turned on, then run a module,
such as r.stream.extract, within gdb so the code can be stepped through?
Rich
