[GRASS-user] r.stream.extract Syntax Problem
Micha Silver
micha at arava.co.il
Sat Apr 7 01:46:04 EDT 2012
Micha Silver
052-366-5918
-----Original message-----
To: grass-users at lists.osgeo.org
Sent: Fri, 06 Apr 2012, 20:16:48 GMT+02:00
Subject: Re: [GRASS-user] r.stream.extract Syntax Problem
On Fri, 6 Apr 2012, Margherita Di Leo wrote:
> I meant something like:
> r.watershed ele=elevation.10m at PERMANENT acc=elevation.10m.weight_acc
> flow=weight -f
followed by:
GRASS 6.5.svn :~/grassdata > r.stream.extract
elev=dem10m.avg accum=dem10m.acc.weighted thresh=1000
stream_rast=dem10m.lm.streams
Load input maps and get start points...
ERROR: Accumulation map does not match elevation map!
[Raster MASK present]
Maybe the MASK is somehow interfereing ??
Still the same error generated. I'm quite puzzled
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120407/f8c8ce09/attachment-0001.html
