[GRASS-user] Re: r.stream.extract Syntax Problem [UPDATE]
Helmut Kudrnovsky
hellik at web.de
Fri Apr 6 14:49:28 EDT 2012
>Yes. Before starting the series of steps leading to extracting streams I
>set the region to dem10m.agv. The region for dem10m.acc is the same.
> I recalculated the weight map with no errors and this makes me wonder
> why
>r.stream.extract with the weighted accumulation map throws and error when
>r.stream.extract without the weighting does not.
> Re-running each step is an option, but the issue seems related to the
>weighted accumulation map so I can re-calculate weights and the weighted
>accumulation but I suspect that's not the problem.
tested here with osgeo4w-wingrass6.4.2, spearfish sample dataset [1] and the
example from the manual page [2]
both, accumulation (A) and weighted (WA) accumulation map, are working:
WA:
r.stream.extract elevation=elevation.10m at PERMANENT
accumulation=elevation.10m.acc.weighed threshold=1000
stream_rast=elevation.10m.streams
Load input maps and get start points...
Set edge points...
A* Search...
Extract streams...
Thin stream segments...
Write raster map
(Fri Apr 06 20:35:36 2012) Befehl ausgeführt (6 sec)
(Fri Apr 06 20:36:36 2012)
A:
accumulation=elevation.10m.acc threshold=1000
stream_rast=elevation.10m.streams.noweight
Set edge points...
A* Search...
Extract streams...
Write raster map
(Fri Apr 06 20:36:42 2012) Befehl ausgeführt (6 sec)
HTH
Helmut
[1] http://grass.osgeo.org/sampledata/spearfish_grass60data-0.3.tar.gz
[2]
https://svn.osgeo.org/grass/grass-addons/grass6/raster/r.stream.extract/description.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-extract-Syntax-Problem-tp4690890p4693391.html
Sent from the Grass - Users mailing list archive at Nabble.com.
