[GRASS-user] Clarifying 'no' comments post configuration
Markus Neteler
neteler at osgeo.org
Mon Apr 9 08:33:09 EDT 2012
On Sun, Apr 8, 2012 at 2:23 PM, RichardC <richtcooper at hotmail.com> wrote:
> I've installed GRASS 6.4.2 and wanted to check if the the features indicated
> by 'no' are no longer supported/deprecated?
You need to switch it on in the configure step:
> BLAS support: no
--with-blas
> DWG support: no
--with-opendwg
> GLw support: no
--with-glw
There are the respective switches:
--with-XXX-includes=DIRS
--with-XXX-libs=DIRS
if needed.
Note that BLAS is almost unused (only on gmath lib). And v.in.dwg is
likely outdated for the latest OpenDWG libraries. There is a related
Addon available.
Hope this helps
Markus
