[GRASS-user] Clarifying 'no' comments post configuration
Glynn Clements
glynn at gclements.plus.com
Mon Apr 9 18:09:58 EDT 2012
RichardC wrote:
> I've installed GRASS 6.4.2 and wanted to check if the the features indicated
> by 'no' are no longer supported/deprecated?
> BLAS support: no
Adds additional functionality to the gmath library. Nothing in GRASS
currently uses that functionality.
> DWG support: no
Required for v.in.dwg, which also requires the OpenDWG library, which
isn't free software.
> GLw support: no
Required for r3.showdspf, which also requires Motif.
