Fwd: Re: [GRASS-user] mysql support
Patrick Dolan
pdolan39 at gmail.com
Wed Apr 11 03:38:11 EDT 2012
Daniel,
After I sent the email, I reinstalled Kyngesbury's 6.4.2-3 release and
had no problem running mysql. The "problem" may be limited to Michael
Barton's snapshots. Regardless, its solved on my end.
Thanks,
Patrick
-------- Original Message --------
Subject: Re: [GRASS-user] mysql support
Date: Wed, 11 Apr 2012 08:59:06 +0200
To: Patrick Dolan <pdolan39 at gmail.com>
CC: grass-user at lists.osgeo.org
Hi Patrick,
Did you compile GRASS from source? I'm using 6.4.2 from the repositories
on Linux and it's definitely got MySQL support.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org <mailto:Lee at isi-solutions.org>
Web: http://www.isi-solutions.org <http://www.isi-solutions.org/>
Am 11. April 2012 03:13 schrieb Patrick Dolan <pdolan39 at gmail.com
<mailto:pdolan39 at gmail.com>>:
Hi out there, I've been trying to connect to the mysql database that
I've been using in GRASS for the past couple of years and I've run
into a problem. Could anyone tell me if they've been confronted with
the same issue? I'm running GRASS on a Mac OS X Lion. I've tried
6.4.2 and 6.4.3 and neither appear to give mysql as an option in
db.connect. I've pasted in the relevant error below:
... > db.connect driver=mysql
ERROR: value <mysql> out of range for parameter <driver>
Legal range: dbf,odbc,ogr,sqlite
Parameters:
driver Driver name
options: dbf,odbc,ogr,sqlite /<- no mysql support?/
default: dbf
Thanks,
Patrick
grass-user mailing list
grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120411/ae2754f5/attachment.html
