[GRASS-user] DTM with contour lines and points
    Pedro Venâncio
    pedrongvenancio at yahoo.com
    Thu Apr 19 18:51:38 EDT 2012
Hello all,
I usually use v.surf.rst to build DTM from contour lines. However, this time I have, in addition to the contour lines, a wide range of elevation points.
How can I use isolines and points at the same time to generate the DTM?
I thought a way to get around, which is to convert the contours to equally spaced points and join these points whith the elevation points layer. Is there a more correct and straightforward way to do?
Thank you very much!
Best regards,
Pedro Venâncio
