[GRASS-user] DTM with contour lines and points
Paolo Cavallini
cavallini at faunalia.it
Fri Apr 20 03:25:05 EDT 2012
Il 20/04/2012 00:51, Pedro Venâncio ha scritto:
> I thought a way to get around, which is to convert the contours to equally spaced points and join these points whith the elevation points layer. Is there a more correct and straightforward way to do?
your real data are vertices anyway, so I think extracting them and
patching them with points is the straightforward way.
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
