[GRASS-user] Adding rows to vector map attribute table
Rich Shepard rshepard at appl-ecosys.com
Mon Apr 23 14:16:35 EDT 2012
   I have a few dozen points to add to a vector map and can do this most
easily using the SQL 'INSERT INTO ...' syntax directly on the postgres
table. Does GRASS automagically update the cat column, or do I do this as
part of the insert statement?
Rich
