[GRASS-user] Adding rows to vector map attribute table
    Daniel Lee
    lee at isi-solutions.org
    Mon Apr 23 14:56:53 EDT 2012
Hi Ric.
I pretty much never work with vectors any more, so I can't verify this
without doing a lot of work. I do believe hat GRASS doesn't necessarily
need a cat column to get by, though - I'm pretty sure it takes the FID
column as is from shapefiles, for example. Which would lead me to think it
doesn't require a primary key. This also makes sense because GRASS vectors
are stored independently of an attribute table in the traditional sense of
the word, if I've understood things currectly. Why don't you try it out?
I'd also be interested to see if GRASS updates the cat column.
Best,
*Daniel*
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
On Apr 23, 2012 8:16 PM, "Rich Shepard" <rshepard at appl-ecosys.com> wrote:
>  I have a few dozen points to add to a vector map and can do this most
> easily using the SQL 'INSERT INTO ...' syntax directly on the postgres
> table. Does GRASS automagically update the cat column, or do I do this as
> part of the insert statement?
> Rich
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120423/1fbc9c06/attachment.html
