[GRASS-user] wms trouble
Maris Nartiss maris.gis at gmail.com
Thu Apr 26 03:09:24 EDT 2012
Just a small correction - every WMS service provider must support
EXCEPTION=XML as a request parameter and return a XML document in case
of an error (see i.e. WMS 1.3.0 7.3.3.11). Every WMS client
implementation just playing with parameters without parsing XML is
doomed to fail (sooner or later).
Just my 0.02,
Maris.
2012. gada 25. aprīlis 14:49 Hamish <hamish_b at yahoo.com> rakstīja:
> Martin Album Ytre-Eide wrote:
>> akl_srtm__0.geotiff' not recognised as a supported file format.
>> ERROR: r.in.gdalwarp: gdalwarp failure.
>> ERROR: r.in.gdalwarp failed
> find the akl_srtm__0.geotiff file in you filesystem (probably
> in $LOCATION/wms_download/ or so) and look inside it. It probably
> contains the text of an error message instead of a tiff image.
> I have not yet figured a reliable cross platform way for it to
> detect that, unfortunately each wms server handles errors in their
> own way, so it is not that easy to test for. (sometimes it is
> even a graphics image which says "error" on the tile)
> if the "akl" you seek is in the south pacific, I may be able
> to help with alternate sources of the data. (guessing from
> airport codes)
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
