[GRASS-user] Problem with v.out.ogr?
Markus Metz
markus.metz.giswork at googlemail.com
Mon Apr 30 10:56:29 EDT 2012
If this happens with GRASS 6.x, I think the expected output can be
obtained by adding the -c flag: Export features with category
(labeled) only. Otherwise all features are exported
v.out.ogr type=line input=esw_g26a format=KML dsn=main.kml layer=7 -c
The meaning of the -c flag has been reverted in GRASS 7 to avoid cases
like these.
Markus M
On Mon, Apr 30, 2012 at 10:28 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 28/04/12 10:35, Micha Silver wrote:
>> On 28/04/2012 00:54, Asher Hoskins wrote:
>>> Hello.
>>> I've got a map with multiple layers that was originally created from a
>>> DXF file (via v.in.dxf). I want to output a single layer as a KML file
>>> so that it can be loaded into Google Earth (for a non-Grass user) but
>>> when I do:
>>> I get all layers output, not just layer 7.
>>> Am I doing something silly here?
>> Not silly, but maybe not what you expect.
>> Layers are database links, so you could very well have a vector with 7
>> layers, where all the geographic features, are in all the layers.
>> Choosing a certain layer mean choosing which attribute table is
>> connected to the features, but not necessarily which features.
> That is not completely true: layers are not connections to attribute tables,
> but a means of allowing different (thematic) identifications of the same
> features in a vector map. You can optionally link each layer to an attribute
> table. Whether a feature exists in a layer or not is determined by whether
> that feature has a category value in that layer.
> See the recently revised vector intro in the docs for more info [1].
> When you display the map, chosing to display only layer 7, what do you see ?
> And what does v.category option=report give you ?
> Moritz
> [1] http://grass.fbk.eu/grass64/manuals/html64_user/vectorintro.html
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
