[GRASS-user] creating two new maps from one existing raster
L. Prevett
prevettl at gmail.com
Thu Aug 16 14:25:02 PDT 2012
On 8/16/12, Janet Choate <jsc.eco at gmail.com> wrote:
> Hi all,
> i have a raster that i simply want to split in two along a line designated
> by me, thereby creating two separate rasters. i have attempted to digitize
> using v.digit, displaying the raster and drawing a line around the area of
> interest. i go through the motions of what i think is closing the line,
> then save and exit. but v.info shows no data attached to this new vector,
> and when i try to display, nothing shows up.
> can anyone tell me how to make 2 rasters out of my 1 along a user specified
> line, or how to successfully digitize this?
> thank you,
> Janet
Hi Janet,
I don't know of a command that just splits a raster (maybe there is one??)
But one way to do it is to use r.digit and create a file named MASK for each
of the separate rasters. Then use r.mapcalc to create new rasters.
Example:
# remove any old MASK file
g.remove MASK
# set the region to the raster you want to split up
g.region rast=old
# display the raster you want to work on (i.e. d.mon start=x0 select=x0)
d.rast old
# run r.digit on the current raster (old)
r.digit output=MASK
## use mouse keys to define new raster named MASK
## save with X
# use r.mapcalc (not g.copy) to create a raster called 'new1'
# that automatically applies the MASK you selected
r.mapcalc new1=old
# clean up and view results
d.erase
g.remove MASK
# view the original raster (old)
d.rast old
# view the new raster
d.rast new1
repeat steps for the other half of the raster (new2, etc...)
note:
Use v.extract and then v.to.rast if you want to create a MASK for features
base on queries (instead of a mouse based MASK).
hth
L. Prevett
