[GRASS-user] Importing ASCII file
sotototo
sogal83 at gmail.com
Thu Aug 23 18:13:58 PDT 2012
Im new to Grass GIS and I have the same problem.
I have an ascii Lidar data set with XYZ values in the following format.
ncols 1999
nrows 1998
xllcorner 459000.27618609
yllcorner 298999.76202791
cellsize 0.5
NODATA_value -9999
-9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999
When I run r.in.arc I get the following error.
Illegal "yllcorner" value in header: "298999.76202791"
Illegal latitude for North
ERROR: Can't get cell header
I tried r.in.xyz and I got this error.
ERROR: Not enough data columns. Incorrect delimiter or column number? Found
the following character(s) in row 1:
[ncols 1999]
I also tried the r3.in.ascii and i got this error.
ERROR: readHeaderString: header value invalid
So could you please tell me if i do something wrong?
I actually want to use the r.sun algorithm to calculate solar radiation and
if Im not mistaken the first step is to import first the ascii file to
GRASS.
Thank you
View this message in context: http://osgeo-org.1560.n6.nabble.com/Importing-ASCII-file-tp4984276p4997492.html
Sent from the Grass - Users mailing list archive at Nabble.com.
