[GRASS-user] Importing ASCII file
Alberto Pettazzi
alberto.pettazzi at meteogalicia.es
Fri Aug 24 01:40:52 PDT 2012
I think you should run r.in.ascii
http://grass.osgeo.org/grass63/manuals/html63_user/r.in.ascii.html
if you want to use r.sun you have to import the digital terrain model
first. then you have to create a slope and an aspect rasters and then
run r.sun with the r.slope.aspect command
http://grass.osgeo.org/grass63/manuals/html63_user/r.slope.aspect.html
and then finally running r.sun
El 24/08/12 03:13, sotototo escribió:
> Hi,
> Im new to Grass GIS and I have the same problem.
> I have an ascii Lidar data set with XYZ values in the following format.
> ncols 1999
> nrows 1998
> xllcorner 459000.27618609
> yllcorner 298999.76202791
> cellsize 0.5
> NODATA_value -9999
> -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999 -9999
> When I run r.in.arc I get the following error.
> Illegal "yllcorner" value in header: "298999.76202791"
> Illegal latitude for North
> ERROR: Can't get cell header
> I tried r.in.xyz and I got this error.
> ERROR: Not enough data columns. Incorrect delimiter or column number? Found
> the following character(s) in row 1:
> [ncols 1999]
> I also tried the r3.in.ascii and i got this error.
> ERROR: readHeaderString: header value invalid
> So could you please tell me if i do something wrong?
> I actually want to use the r.sun algorithm to calculate solar radiation and
> if Im not mistaken the first step is to import first the ascii file to
> GRASS.
> Thank you
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Importing-ASCII-file-tp4984276p4997492.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Alberto Pettazzi
MeteoGalicia - Departamento de Climatología y Observación
Consellería de Medio Ambiente, Territorio e Infraestruturas
Rúa de Roma, 6
15707 Santiago de Compostela. A Coruña
Teléfono: +34-881-999646
e-mail: alberto.pettazzi at meteogalicia.es
<mailto:alberto.pettazzi at meteogalicia.es>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120824/68efbe01/attachment.html>
