[GRASS-user] can't start from a BARRIER / Wildfire suite
Margherita Di Leo
diregola at gmail.com
Tue Aug 28 05:58:56 PDT 2012
Hi All,
I have some troubles running the Wildfire suite in grass. In particular,
when i run r.spread I get the following error message:
WARNING: can't start from a BARRIER at cell (416,305), request ignored
WARNING: can't start from a BARRIER at cell (417,305), request ignored
WARNING: can't start from a BARRIER at cell (418,305), request ignored
I checked the input and this is due to the fact that r.ros produces a
r.ros.base map which is all 0 and null.
r.info map=r_ros0.base
| Layer: r_ros0.base Date: Tue Aug 28 13:58:37 2012
| Mapset: PERMANENT Login of Creator: leomarg
| DataBase: /home/leomarg/grassdata
| Title: ( r_ros0.base )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 744
| Columns: 889
| Total Cells: 661416
| Projection: Lambert Azimuthal Equal Area
| N: 1903000 S: 1828600 Res: 100
| E: 3433100 W: 3344200 Res: 100
| Range of data: min = 0 max = 0
| Data Description:
| generated by r.ros
So I checked the input of r.ros but i'm puzzled because everything looks
good to me, I can't see any obvious error. In the manual I read:
3. The output units for the base and maximum ROSes are in cm/minute rather
than ft/minute, which is due to that a possible zero ft/minute base ROS
value and a positive integer ft/minute maximum ROS would result in
calculation failure in the r.spread program.
So if I understand correctly, this can be due to a possible unit mismatch.
I give the velocity of wind in feet/minute and the direction in degrees, as
required by the manual.
Where am I wrong?
Thanks.
madi
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120828/ebc69ae4/attachment-0001.html>
