[GRASS-user] can't start from a BARRIER / Wildfire suite
Margherita Di Leo diregola at gmail.com
Tue Aug 28 08:35:06 PDT 2012
OK solved. I figured out that it was actually a problem in the units i used
in the input maps.
On Tue, Aug 28, 2012 at 2:58 PM, Margherita Di Leo <diregola at gmail.com>wrote:
> Hi All,
> I have some troubles running the Wildfire suite in grass. In particular,
> when i run r.spread I get the following error message:
> WARNING: can't start from a BARRIER at cell (416,305), request ignored
> WARNING: can't start from a BARRIER at cell (417,305), request ignored
> WARNING: can't start from a BARRIER at cell (418,305), request ignored
> I checked the input and this is due to the fact that r.ros produces a
> r.ros.base map which is all 0 and null.
> r.info map=r_ros0.base
>  | Layer:    r_ros0.base                    Date: Tue Aug 28 13:58:37 2012
>  | Mapset:   PERMANENT                      Login of Creator: leomarg
>  | Location: Europe
>  | DataBase: /home/leomarg/grassdata
>  | Title:     ( r_ros0.base )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 0
>  |   Data Type:    CELL
>  |   Rows:         744
>  |   Columns:      889
>  |   Total Cells:  661416
>  |        Projection: Lambert Azimuthal Equal Area
>  |            N:    1903000    S:    1828600   Res:   100
>  |            E:    3433100    W:    3344200   Res:   100
>  |   Range of data:    min = 0  max = 0
>  |   Data Description:
>  |    generated by r.ros
> So I checked the input of r.ros but i'm puzzled because everything looks
> good to me, I can't see any obvious error. In the manual I read:
> 3. The output units for the base and maximum ROSes are in cm/minute rather
> than ft/minute, which is due to that a possible zero ft/minute base ROS
> value and a positive integer ft/minute maximum ROS would result in
> calculation failure in the r.spread program.
> So if I understand correctly, this can be due to a possible unit mismatch.
> I give the velocity of wind in feet/minute and the direction in degrees, as
> required by the manual.
> Where am I wrong?
> Thanks.
> madi
> Dr. Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120828/1928e96a/attachment.html>
