[GRASS-user] Vector import combo: db.in.ogr/v.in.db data type casting problem
Markus Neteler
neteler at osgeo.org
Wed Aug 29 03:56:55 PDT 2012
On Mon, Aug 20, 2012 at 3:56 PM, "Peter Löwe" <peter.loewe at gmx.de> wrote:
> hi,
> here is an issue (probably float/integer typcasting related) issue when importing a large CSV dataset of vector points into GRASS6.4.2.
> The data set contains hundreds of columns,
Note that the default DBF driver does not support an "unlimited"
amount of columns
(the specs suggest 128 columns max).
> so v.in.ascii is not an option (the columns option-string would be ungodly long).
> Instead, the data is transformed into a DBF
Please use SQLite instead, also as DB backend for such operations
(ideally, due to recent fixes, the current 6.4.svn).
Best,
Markus
