[GRASS-user] Vector import combo: db.in.ogr/v.in.db data type casting problem
"Peter Löwe"
peter.loewe at gmx.de
Wed Aug 29 04:00:30 PDT 2012
Hi Markus,
> Note that the default DBF driver does not support an "unlimited"
> amount of columns
> (the specs suggest 128 columns max).
> Please use SQLite instead, also as DB backend for such operations
> (ideally, due to recent fixes, the current 6.4.svn).
That's correct. Thanks for following up on this.
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
