[GRASS-user] new wxGUI feature: Map Swipe
Anna Kratochvílová kratochanna at gmail.com
Fri Aug 31 04:15:21 PDT 2012
On Fri, Aug 31, 2012 at 12:55 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> I am also just asking... contributing code is unfortunately way out of my
> league.
> I am somewhat indifferent to whether synchronized display of multiple maps
> would be a general feature of map display or part of the swipe tool. I can
> imagine that it would be easier to make it initially part of a separate
> tool, but I am no developer so I could be completely wrong.
Maybe it would be easier to develop a separate tool for this because
otherwise it would probably need some refactoring. Map Swipe was meant
for a different purpose and adding this new functionality would cause
some problems, for example what should it do with the slider?. I would
prefer to put this functionality to Map Displays because it seems
natural to me to use it there.
Anna
> Cheers
> Paulo
> On 08/31/2012 11:56 AM, Moritz Lennert wrote:
> On 31/08/12 11:27, Anna Kratochvílová wrote:
> Hi,
> On Fri, Aug 31, 2012 at 11:07 AM, Paulo van Breugel
> Hi Anna
> This looks like a very useful tool, and it works perfectly (running grass 7
> on Ubuntu 12.04), thanks!
> If I may make a feature request. Would it be very difficult to implement an
> option where rather then splitting the area between the two maps, the same
> area is shown for both maps (i.e., mirrored maps). In that option, moving
> one map would move the other map too. This makes it easier to see changes
> between two maps in detail. In case my explanation isn't clear, a nice
> example is the MIrrorMap plug-in for QGIS.
> Seems clear to me. I added it to map swipe wiki page, you can edit it.
> I remember someone on mailing list was asking about similar
> functionality - synchronize display region extent of more Map Displays
> - could it be what you mean?
> http://trac.osgeo.org/grass/ticket/1669
> I'm not sure that this should be part of the swipe tool. I'd rather see this
> as a general feature of Map Displays, i.e. the option to linked any number
> of Map Displays so that when you pan / zoom in one the other(s) adjust
> automagically. Then again, I'm only the one asking, not doing ... ;-)
> Moritz
