[GRASS-user] new wxGUI feature: Map Swipe
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Aug 31 03:55:28 PDT 2012
I am also just asking... contributing code is unfortunately way out of
my league.
I am somewhat indifferent to whether synchronized display of multiple
maps would be a general feature of map display or part of the swipe
tool. I can imagine that it would be easier to make it initially part of
a separate tool, but I am no developer so I could be completely wrong.
Cheers
Paulo
On 08/31/2012 11:56 AM, Moritz Lennert wrote:
> On 31/08/12 11:27, Anna Kratochvílová wrote:
>> Hi,
>> On Fri, Aug 31, 2012 at 11:07 AM, Paulo van Breugel
>> <p.vanbreugel at gmail.com> wrote:
>>> Hi Anna
>>> This looks like a very useful tool, and it works perfectly (running
>>> grass 7
>>> on Ubuntu 12.04), thanks!
>>> If I may make a feature request. Would it be very difficult to
>>> implement an
>>> option where rather then splitting the area between the two maps,
>>> the same
>>> area is shown for both maps (i.e., mirrored maps). In that option,
>>> moving
>>> one map would move the other map too. This makes it easier to see
>>> changes
>>> between two maps in detail. In case my explanation isn't clear, a nice
>>> example is the MIrrorMap plug-in for QGIS.
>> Seems clear to me. I added it to map swipe wiki page, you can edit it.
>> I remember someone on mailing list was asking about similar
>> functionality - synchronize display region extent of more Map Displays
>> - could it be what you mean?
> http://trac.osgeo.org/grass/ticket/1669
> I'm not sure that this should be part of the swipe tool. I'd rather
> see this as a general feature of Map Displays, i.e. the option to
> linked any number of Map Displays so that when you pan / zoom in one
> the other(s) adjust automagically. Then again, I'm only the one
> asking, not doing ... ;-)
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120831/a957d0a9/attachment-0001.html>
