[GRASS-user] Grass7 on FreeBSD 9.0 : Compilation Error.
Pierre Stévens
pierre at geobsd.com
Sun Dec 2 12:05:32 PST 2012
Hi Grass Users,
I'm trying to install Grass7 on FreeBSD 9.0 with the latest SVN snapshot.
The problem comes with " ./configure " command.
The error is : " ***Unknown platform: i386-unknown-freebsd9.0*** ".
Maybe one of us can help FreeBSD users.
Here is the outcome of " ./configure " command :
checking host system type... i386-unknown-freebsd9.0
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /usr/local/src/grass7
checking for build directory... /usr/local/src/grass7
checking for svnversion... /usr/local/bin/svnversion
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
configure: error: ***Unknown platform: i386-unknown-freebsd9.0***
Pierre Stévens
GeoBSD
+32 479 87 01 96
Rue des Ponts 5b, 4684 Haccourt
