[GRASS-user] Grass7 on FreeBSD 9.0 : Compilation Error.
Markus Neteler
neteler at osgeo.org
Sun Dec 2 14:06:30 PST 2012
On Sun, Dec 2, 2012 at 9:05 PM, Pierre Stévens <pierre at geobsd.com> wrote:
> Hi Grass Users,
> I'm trying to install Grass7 on FreeBSD 9.0 with the latest SVN snapshot.
> The problem comes with " ./configure " command.
> The error is : " ***Unknown platform: i386-unknown-freebsd9.0*** ".
> Maybe one of us can help FreeBSD users.
We need to update "config.guess" and "config.sub". In times of git, I no
longer understand where to fetch these files:
http://git.savannah.gnu.org/cgit/autoconf.git
Any idea?
Markus
> Here is the outcome of " ./configure " command :
> checking host system type... i386-unknown-freebsd9.0
> checking for gcc... gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... no
> checking for full floating-point support... yes
> checking for pwd... /bin/pwd
> checking for source directory... /usr/local/src/grass7
> checking for build directory... /usr/local/src/grass7
> checking for svnversion... /usr/local/bin/svnversion
> checking for MacOSX App... no
> checking for MacOSX architectures... no
> checking for MacOSX SDK... no
> checking how to build libraries... shared
> configure: error: ***Unknown platform: i386-unknown-freebsd9.0***
> Pierre Stévens
> GeoBSD
> +32 479 87 01 96
> Rue des Ponts 5b, 4684 Haccourt
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
