[GRASS-user] The attribute table -sqlite- is not displayed through the GUI
Lluís Vicens lluis at sigte.udg.es
Tue Dec 11 07:43:58 PST 2012
Dear all,
One of my students has been experiencing severe problems when she tries
to use sqlite in conjunction with  GRASS 6.4.2 and GRASS 7. When she
imports a vector layer into her mapset based on a sqlite connection (she
has established a new connection through db.connect command firstly),
GRASS launches an error whose origin is probably due to the
incompatibility between the version of sqlite and the driver that GRASS
6.4.2 has.
Then, she tries to import this same layer using GRASS 7 and she finishes
the import process successfully. She can also execute db.describe -c
layer to see the columns of the attribute table but, when she wants to
open the attribute table through the GUI, the software crashes all the
time, and she needs to restart GRASS without taking a look to the
attribute table.
It's an online course and the other students doesn't experienced such
problems.
¿Has anybody else experienced this kind of problems? ¿Is it an
identified problem?¿Any hint?
Thanks in advance
She's running:
GRASS 6.4.2
GRASS 7.0
sqlite3
Windows 7 64bits
Lluís
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121211/45f5891e/attachment.html>
