[GRASS-user] r.drain problem when flow reach the border
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Sun Dec 30 14:44:57 PST 2012
Hi Markus
I am using this commands.
r.cost -k input=friction_landuse_roads output=cost_map
start_points=map_source_pt stop_points=map_target_pt --o
r.drain input=cost_map output=drain_map vector_points=map_target_pt --o
I have not a direction map, and as for other source-target-friction
maps everything works fine without direction map I thougth that this
should work for all.
If you have the chance, please run the command and take a look that
the drain line finish on right border.
best wishes
miltinho
2012/12/30, Markus Metz <markus.metz.giswork at gmail.com>:
> On Sun, Dec 30, 2012 at 8:59 PM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
>> Hi Rashad
>> I tested with the trunk svn, but apparently it still not worked to me.
>> Are you able to test with my datased?
>> https://www.yousendit.com/download/UW16RE9zTkxlM1JBSXNUQw
> What are the commands you used? I found
> r.drain input=custo_aux_cost output=custo_aux_cost_drain
> You need to also provide a direction map with the indir option of r.drain.
> Markus M
>> Thanks!
>> miltinho
>> 2012/12/27, Mohammed Rashad <mohammedrashadkm at gmail.com>:
>>> Hi Milton,
>>> I think this fix will solve the problem[0]. For elevation data there
>>> might
>>> be cases where no path exists ie, only single pixel is the selected path.
>>> I
>>> had tested it by myself and it worked.
>>> Please apply the patch and let me know.
>>> If any problem comes in compilation or doing r.drain let me know. It
>>> will
>>> be great if you can share the test data you are using in case not
>>> working
>>> after applying the patch
>>> [0] http://trac.osgeo.org/grass/attachment/ticket/1840/r.drain.diff
>>> [1] http://trac.osgeo.org/grass/attachment/ticket/1840/drain.c
>>> On Thu, Dec 27, 2012 at 2:31 AM, Milton Cezar Ribeiro <
>>>> Hi Mohamed and Markus
>>>> Mohamed, thanks for your reply, I will wait for a solution within GRASS
>>>> Markus, thanks for your reply,. Sorry but I disagree a tiny bit,
>>>> because is expected that between a source and target I will find a
>>>> solution with the Least Cost path. Do you think that is there any
>>>> situation where a least cost between source and target will not be
>>>> found? Maybe if other software provide the soluction, although is not
>>>> the bestest option, I prefere receive one complete output than a
>>>> broken one.
>>>> Happy new year!
>>>> miltinho
>>>> 2012/12/23, Markus Metz <markus.metz.giswork at gmail.com>:
>>>> > On Sun, Dec 23, 2012 at 7:07 PM, Milton Cezar Ribeiro
>>>> >> Dear all,
>>>> >> I am running a least cost path analysis combining r.cost and
>>>> >> r.drain.
>>>> >> But on some cases, when the least cost path between source and
>>>> >> target
>>>> >> reach the border of my map, r.drain stop on that position, and
>>>> >> target
>>>> >> point isn´t reached.
>>>> > This is correct because at the borders, the direction can not be
>>>> > determined, the path could lead out of the current region, you can
>>>> > not
>>>> > tell.
>>>> > Running on other softwares the algorithms the
>>>> >> source and target is connected using edges without problem.
>>>> > If in doubt, I would call it a bug in that other software.
>>>> >> Any hint are welcome.
>>>> > Try to expand the current region
>>>> > Markus M
>>>> Miltinho - mcr at rc.unesp.br
>>>> Laboratório de Ecologia Espacial e Conservação - LEEC
>>>> Depto de Ecologia - UNESP - Rio Claro
>>>> Av. 24A, 1515- Bela Vista
>>>> 13506-900 Rio Claro, SP, Brasil
>>>> Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
>>>> Cel: 19 9853-3220 / 19 9853-5430
>>>> Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
>>>> PG ECO & BIODIV
>>>> http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
>>>> CV
>>>> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
>>>> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Regards,
>>> Rashad
>> PG ECO & BIODIV
>> CV
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
