[GRASS-user] Re: i.pr --> g.extension and compiling error on ubuntu 11.10 64 bit
Gabriele N. gis.gn at libero.it
Wed Feb 1 07:57:32 EST 2012
hamish-2 wrote
> Gabriele wrote:
>> I installed but I have the same error.
>> With g.extension I can install other add-ons (eg
>> i.landsat.acca) but not i.pr
> but are they actually on the disk somewhere,
> slightly in the wrong place?
> i.e. if you look in $GRASS_ADDON_PATH/ is there
> a bin/ dir in there that has them? if so, just
> move them into the $GRASS_ADDON_PATH dir manually.
> (the automatic move fails as the module names do
> not match the directory name, same trouble with
> gipe, mcda, ...)
Ciao Hamish, I do not understand what you said:) but I did the following:
I copied the folder i.pr  in /usr/local/grass-6.5.svn/bin/ (where there is
also i.landsat.acca that I installed with g.extension).
Then
cd /usr/local/grass-6.5.svn/bin/i.pr/
and
make MODULE_TOPDIR=/usr/local/grass-6.5.svn
Now it seems to work ... I start to try it.
thank you very much
Gabriele
View this message in context: http://osgeo-org.1560.n6.nabble.com/i-pr-g-extension-and-compiling-error-on-ubuntu-11-10-64-bit-tp4352067p4356276.html
Sent from the Grass - Users mailing list archive at Nabble.com.
