[GRASS-user] Re: winGrass, ODBC and MS Access database
Christine
geo.guide at web.de
Thu Feb 2 18:35:47 EST 2012
The access-database is not a personal geodatabase. It contains point
coordinates and it is no problem to read and visualize the data with QGIS or
gvSIG. Meanwhile I found odbc.exe manually in the QGIS/GRASS installation
folder. Curious thing, that Windows Explorer search does'nt find it ...
1. Connect to database (works):
db.connect --verbose driver=odbc database=Testdatenbank
2. Attempts to import Data of the database with
v.external --verbose dsn=Testdatenbank output=Testdaten layer=GWM
db.in.ogr --verbose dsn=Testdatenbank db_table=MSSTAMM output=GWM key=OID
v.in.ogr --verbose dsn=Testdatenbank output=GWM
all fail. In all three cases a system error message occurs stating a problem
with odbc.exe and GRASS hangs. Python.exe also crashes or hangs.
Actually I am a newbie with GRASS GIS. Am I doing something wrong ?
Have saved error reports that should be send to Microsoft. Would that be
useful ?
Kind regards, Christine
View this message in context: http://osgeo-org.1560.n6.nabble.com/Re-winGrass-ODBC-and-MS-Access-database-tp4356636p4360354.html
Sent from the Grass - Users mailing list archive at Nabble.com.
