[GRASS-user] Re: winGrass, ODBC and MS Access database
Martin Landa landa.martin at gmail.com
Thu Feb 2 18:43:35 EST 2012
2012/2/3 Christine <geo.guide at web.de>:
> 1. Connect to database (works):
> db.connect --verbose driver=odbc database=Testdatenbank
It means that attribute data for newly created vector maps will be
stored in 'Testdatenbank' using `odbc` driver, nothing else. Geometry
will be stored in GRASS native format. Controlling external format for
output map can be done using `v.external.out` (GRASS 7 only).
> 2. Attempts to import Data of the database with
> v.external --verbose dsn=Testdatenbank output=Testdaten layer=GWM
> db.in.ogr --verbose dsn=Testdatenbank  db_table=MSSTAMM output=GWM key=OID
> v.in.ogr --verbose dsn=Testdatenbank output=GWM
> all fail. In all three cases a system error message occurs stating a problem
> with odbc.exe and GRASS hangs. Python.exe also crashes or hangs.
Could you report exact error? It's hard to guess.
Does
v.external -f
report ODBC format?
What
v.external dsn=Testdatenbank -l
says?
I have no experience with ODBC at all (from user POV), anyway [1] says
something about ODBC prefix. So I would assume
v.external dsn=ODBC:Testdatenbank -l
is right.
Martin
[1] http://gdal.org/ogr/drv_odbc.html
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
