[GRASS-user] ps.map rotatecolumn argument
Vincent Bain
bain at toraval.fr
Mon Feb 6 12:21:03 EST 2012
No way to reproduce the problem.
I am wondering if there could be something wrong with cat values that
obviously can differ from one layer to another.
In my case, the point map used to draw rotated symbols was obtained via
v.to.points. I use layer 2 which contain a 'cat' key field that is
different from the 'cat' key field of layer 1.
Could ps.map confuse between these cat lists ?
(once again : symbols appear correctly rotated in my dataset when
displayed in wxGUI)
Sorry for bothering with it,
Vincent.
Le dimanche 05 février 2012 à 18:55 +0100, Vincent Bain a écrit :
> Hello Hamish,
> thank you for your reply, I knew you were the author of this
> feature ;-), read this in a former post.
> (I had to cope the whole day with ice in pipes, so sorry for the late
> reaction...)
> I run grass on a 64bit linux system (debian), freshly updated 6.4
> version from svn. Angles are expressed in degrees counterclockwise from
> East.
> I tried to reproduce the problem on North Carolina dataset(1). But
> unfortunately for me... It works !
> Note : the default database settings in north carolina dataset link
> vectors to dbf driver. In my case, vector maps are related to pg driver.
> May it be the source of the problem ?
> Another detail : the fieldname containing my rotation values is
> 'angle' ; could it cause a failure in your c script ?
> Thank you in advance,
> Vincent
> ________________
> (1)
> wrote a ps.map file with this argument:
> vpoints points_of_interest
> color black
> eps /usr/local/grass-6.4.2svn/etc/paint/patterns/cross_normal.eps
> rotatecolumn elev_m
> size 1
> end
> symbols appear correctly rotated on the output.
> Le samedi 04 février 2012 à 12:13 -0800, Hamish a écrit :
> > Vincent wrote:
> > > Has anyone experienced the ability of ps.map's
> > > vpoints instruction to choose from a rotatecolumn
> > > to orient symbols on a map ?
> > yes, I add that code.
> > > In my case, map arrow contains about 50 points but
> > > ps.map only displays a few ones at correct angle.
> > > The database field is integer, angles are specified
> > > ccw from east.
> > can you reproduce it using one of the standard demo
> > datasets?
> > what version of grass? what platform?
> > angle in degrees?
> > Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
