[GRASS-user] v.to.rast in a python loop, error
glynn at gclements.plus.com
Thu Feb 9 20:22:52 EST 2012
Scott Sinclair wrote:
> Have you tried adding flags = '-o' as an argument to
> grass.run_command? That will overwrite the output raster if it already
> exists.
Actually, it will raise a ScriptError if you're running anything later
than 6.4.1. If you want to pass the --overwrite flag to the module,
you should pass overwrite=True to run_command() etc.
