[GRASS-user] v.to.rast in a python loop, error
Scott Sinclair
scott.sinclair.za at gmail.com
Fri Feb 10 01:00:49 EST 2012
On 10 February 2012 03:22, <glynn at gclements.plus.com> wrote:
> Scott Sinclair wrote:
>> Have you tried adding flags = '-o' as an argument to
>> grass.run_command? That will overwrite the output raster if it already
>> exists.
> Actually, it will raise a ScriptError if you're running anything later
> than 6.4.1. If you want to pass the --overwrite flag to the module,
> you should pass overwrite=True to run_command() etc.
Thanks - I haven't used anything later than 6.4.1. Good to know.
Cheers,
Scott
