[GRASS-user] Re: How to rescale an aspect map
    leonidas
    leonidas_liakos at yahoo.gr
    Mon Feb 13 02:31:27 EST 2012
I need the most suitable areas (with SE aspect) to have the value of 255 and
the unsuitable (North aspect) to have the value of 0. Grass returns N=90 and
SE=315 and flat=0.
So the minimum value of aspect raster is flat areas and the max is areas
with 359 degrees of east.
I should set North as the minimum value and SE as the max value (most
suitable areas).
I should rescale the raster because I need to include it in an AHP method.
All rasters will be rescaled in a common 0-255 scale.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-rescale-an-aspect-map-tp4377272p4464174.html
Sent from the Grass - Users mailing list archive at Nabble.com.
