[GRASS-user] v.to.rast in a python loop, error
Moritz Lennert
mlennert at club.worldonline.be
Mon Feb 13 10:11:46 EST 2012
On 13/02/12 15:19, Johannes Radinger wrote:
> -------- Original-Nachricht --------
>> Datum: Mon, 13 Feb 2012 13:18:58 +0100
>> Von: Moritz Lennert<mlennert at club.worldonline.be>
>> An: Johannes Radinger<JRadinger at gmx.at>
>> CC: grass-user at lists.osgeo.org, glynn at gclements.plus.com
>> Betreff: Re: [GRASS-user] v.to.rast in a python loop, error
>>>> Datum: Mon, 13 Feb 2012 11:46:21 +0100 Von: Moritz
>>>> Lennert<mlennert at club.worldonline.be> An: Johannes
>>>> Radinger<JRadinger at gmx.at> CC: grass-user at lists.osgeo.org,
>>>> glynn at gclements.plus.com Betreff: Re: [GRASS-user] v.to.rast in a
>>>> python loop, error
>>>> On 13/02/12 11:32, Johannes Radinger wrote:
>>>>> And my output with although all maps were removed manually with
>>>>> g.remove
>>>> and cross checked:
>>>>> Launching script '/Users/Johannes Radinger/Desktop/test2.py'...
>>>>> (Mon Feb 13 11:12:27 2012) /Users/Johannes
>>>>> ---------------------------------------------- raster files
>>>>> available in mapset<PERMANENT>: basins elevation_shade
>>>>> lakes soils elevation geology landuse
>>>>> raster files available in mapset<user1>: rast_FULL_HYDRO
>>>>> rast_LENGTH
>>>> Both maps _do_ exist in mapset user1. So it is normal that the
>>>> error appears.
>>> That is the strange behavior I am describing: Although g.list is
>>> first in the script, v.to.rast is processed first (at least
>>> partly)...or something like that...
>> Sounds weird to me. You could try to suspend execution after each line
>> using time.sleep(secs).
>> Note that in the last version of the script you posted the line with
>> g.remove is commented out.
> Hi again...
> I know, g.remove was commented out. If not everything is working. My interpretation is: the new raster maps are created first (before anything else is performed) then g.remove removes these and thereafter v.to.rast is processed...
> This is also supported when i try your suggestion (with time.sleep). Here what I run (and please look at the order of the output)? Is there anything running in parallel?
> #!/usr/bin/env python
> import sys
> import time
> import grass.script as grass
> import grass.script.setup as gsetup
> def main():
> print "start"
> sys.stdout.flush()
> grass.run_command("g.list",
> type = "rast")
> time.sleep(5)
> print "1st g.list over"
> sys.stdout.flush()
> type = "rast")
> time.sleep(5)
> print "2nd g.list over"
> sys.stdout.flush()
> for i in ['FULL_HYDRO','LENGTH']:
> grass.run_command("v.to.rast",
> input = "streams at PERMANENT",
> output = "rast_"+i,
> type = "line",
> use = "attr",
> column = i)
> time.sleep(5)
> return 0
> if __name__ == "__main__":
> sys.exit(main())
> Output:
> (Mon Feb 13 15:08:07 2012)
> start
> raster files available in mapset<PERMANENT>:
> basins elevation_shade lakes soils
> rast_FULL_HYDRO rast_LENGTH
> 1st g.list over
> ERROR: option<output>:<rast_FULL_HYDRO> exists.
> ERROR: option<output>:<rast_LENGTH> exists.
> 2nd g.list over
> (Mon Feb 13 15:08:23 2012) Command finished (15 sec)
> Looks weird as "2nd g.list over" is printed after the ERROR, resp.
> the ERROR is produced by v.to.rast before the print statement is processed...
> I launch the script from within GRASS6.5SVN (Mac OSX) from File -> launch script.
Ok, I can reproduce your error using File->Launch script. No idea where
that comes from, I'll try to look into it.
For the time being, just use g.remove or launch your script in the terminal.
Moritz
