[GRASS-user] v.to.rast in a python loop, error
Moritz Lennert
mlennert at club.worldonline.be
Mon Feb 13 10:29:58 EST 2012
On 13/02/12 16:11, Moritz Lennert wrote:
> On 13/02/12 15:19, Johannes Radinger wrote:
>> #!/usr/bin/env python
>> import sys
>> import time
>> import grass.script as grass
>> import grass.script.setup as gsetup
>> def main():
>> print "start"
>> sys.stdout.flush()
>> grass.run_command("g.list",
>> type = "rast")
>> time.sleep(5)
>> print "1st g.list over"
>> sys.stdout.flush()
>> type = "rast")
>> time.sleep(5)
>> print "2nd g.list over"
>> sys.stdout.flush()
>> for i in ['FULL_HYDRO','LENGTH']:
>> grass.run_command("v.to.rast",
>> input = "streams at PERMANENT",
>> output = "rast_"+i,
>> type = "line",
>> use = "attr",
>> column = i)
>> time.sleep(5)
>> return 0
>> if __name__ == "__main__":
>> sys.exit(main())
>> Output:
>> Launching script '/Users/Johannes Radinger/Desktop/test2.py'...
>> (Mon Feb 13 15:08:07 2012)
>> start
>> raster files available in mapset<PERMANENT>:
>> basins elevation_shade lakes soils
>> elevation geology landuse
>> raster files available in mapset<user1>:
>> rast_FULL_HYDRO rast_LENGTH
>> 1st g.list over
>> ERROR: option<output>:<rast_FULL_HYDRO> exists.
>> ERROR: option<output>:<rast_LENGTH> exists.
>> 2nd g.list over
>> (Mon Feb 13 15:08:23 2012) Command finished (15 sec)
>> Looks weird as "2nd g.list over" is printed after the ERROR, resp.
>> the ERROR is produced by v.to.rast before the print statement is
>> processed...
>> I launch the script from within GRASS6.5SVN (Mac OSX) from File ->
>> launch script.
> Ok, I can reproduce your error using File->Launch script. No idea where
> that comes from, I'll try to look into it.
> For the time being, just use g.remove or launch your script in the
> terminal.
This is a bit over my head as I don't have a good view of how the GUI
works (CC to Martin), but AFAICT the script is run through RunCmd on
line 599 in gui/wxpython/gui_core/goutput.py [1].
So it quite definitely seems a wxgui problem, but I don't know how to go
further with this. You should probably file a bug report.
Moritz
[1]
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py#L599
