[GRASS-user] How to link or combine adjacent vector lines
Stefan Luedtke sluedtke at gfz-potsdam.de
Mon Feb 13 13:54:33 EST 2012
I tried the short one of course , worked perfectly ;-)
Thanks a lot for your efforts.
Cheers,
stefan
On Mon, 2012-02-13 at 03:06 -0800, Hamish wrote:
> Moritz wrote:
> > With options first and multi v.build.polylines just copies
> > the attribute tables as is, i.e. it does not delete any
> > lines for which there are no more category values in the
> > vector file.
> > To create an attribute table that corresponds to the current
> > vector amp with the following steps (supposing that the
> > vector map is called river_poly):
> > db.copy from_table=river_poly to_table=river_bak # create
> > backup of existing table
> > v.db.connect -d river_poly # erase line between vector map
> > and table river_poly
> > db.droptable river_poly # erase table river_poly
> > v.db.addtable river_poly # create new table for vector map
> > river_poly
> > If you do all this using an SQL backend (e.g. SQLite or
> > PostgreSQL), you can then use v.db.join to join any
> > attributes from the original table river_bak to the new
> > table river_poly.
> would 'v.extract list=1-9999999' also work?
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120213/3351842d/attachment.html
