[GRASS-user] Rotating/sizing labels based on DB column?
Asher Hoskins
asher at piceur.com
Mon Feb 13 15:34:58 EST 2012
Hello.
I'm using some Ordnance Survey street-level Mastermap data which
implements street names, house numbers, etc. as map points linked to a
database containing the text to print, its size and its rotation.
I can produce basic map labels using v.label:
v.label labels=xxx map=g26a column=textString layer=3 size=1.50
to get:
http://www.piceur.com/misc/grass/non_rotated_text.png
Before I start hacking the label paint files myself (the format looks
nice and simple), is there a way to set size and rotation information on
a per-label basis? I'm aiming for a result that looks something like
this (rendered by the Edina Digimap service):
http://www.piceur.com/misc/grass/digimap_render.png
The final map is to be the bottom layer of a stack of moderately
complicated information and so I'd like to be able to render it myself
in a simplified form rather than just importing tiles from the Ordnance
Survey.
Thanks,
Asher.
