[GRASS-user] Re: Problem with i.cluster
Eliette
reliette at student.ethz.ch
Fri Feb 24 12:29:09 EST 2012
Hi everyone,
I could solve this problem like this:
First: read the rows and columns of your raster map using r.info. Appropiate
sample intervals are obtained by dividing that number by 100.
For example, if you have:
Rows: 7603
Columns: 8556
Good sample intervals are: 76,86
So, set up your region to match one of the raster maps that you are using
(if you defined a group it can be any of the maps in the group), for this
use g.region.
Now you should be able to run i.cluster with the sample intervals = 76,86.
Worked for me.
Here you can find more info regarding this topic, it is very helpful even if
you are ussing another version of GRASS:
http://grass.osgeo.org/gdp/imagery/grass4_image_processing.pdf
Best,
Eliette
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-i-cluster-tp3887750p4503475.html
Sent from the Grass - Users mailing list archive at Nabble.com.
