[GRASS-user] Re: GUI command works,
but not the command copied in the CLI
PuffDany
daniel.kaeser at unine.ch
Mon Feb 27 07:44:31 EST 2012
Thanks very much for your input, Maris. Unfortunately it didn't make the
think work. Here's the command:
r.in.arc input=G:\Data\GIS projects\GRASSdata\Emmental\PERMANENT\srtm.txt
output=srtm11 (you can also see it in the printscreen of email 1)
This command is a direct copy/paste from the GUI, which works fine, and its
not a problem of the filename already existing, as I have given new file
names.
Many thanks
PuffDany
View this message in context: http://osgeo-org.1560.n6.nabble.com/GUI-command-works-but-not-the-command-copied-in-the-CLI-tp4514528p4514605.html
Sent from the Grass - Users mailing list archive at Nabble.com.
