[GRASS-user] Re: GUI command works, but not the command copied in the CLI
Benjamin Ducke benducke at fastmail.fm
Mon Feb 27 07:57:44 EST 2012
Have you tried Maris' suggestion and put quotes around
the value of the input= option?
The command that you copied below has a space in the
path leading to srtm.txt. If you do not quote this,
command line parsing _will_ break. This seems to be
the cause of your troubles. To make things easier,
avoid using folder names with spaces. For a quick
fix, rename "GIS projects" -> "GIS_projects".
Ben
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
  benducke AT fastmail.fm
On Mon, Feb 27, 2012, at 04:44, PuffDany wrote:
> Thanks very much for your input, Maris. Unfortunately it didn't make the
> think work.  Here's the command:
> r.in.arc input=G:\Data\GIS projects\GRASSdata\Emmental\PERMANENT\srtm.txt
> output=srtm11 (you can also see it in the printscreen of email 1)
> This command is a direct copy/paste from the GUI, which works fine, and
> its
> not a problem of the filename already existing, as I have given new file
> names.
> Many thanks
> PuffDany
> http://osgeo-org.1560.n6.nabble.com/GUI-command-works-but-not-the-command-copied-in-the-CLI-tp4514528p4514605.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
