[GRASS-user] Difference in sunset/sunrise time between r.sun and r.sunmask
Büro Seling buero-seling at t-online.de
Mon Jan 2 10:46:44 EST 2012
Am 02.01.2012 16:19, schrieb Stephen Sefick:
> If you use R there is a sunrise.set function in the StreamMetabolism
> package (shameless promotion).  That may be helpful.
> Stephen Sefick
> On 01/02/2012 06:57 AM, Büro Seling wrote:
>> Dear Group!
>> Happy New Year @all!
>> I work on a Linux GRASS 6.4.2 RC1. The area of interest is in central
>> Europe and
>> the projection is WGS84(EPSG:4326).
>> When I use the r.sun module and let it show the sunset/sunrise time
>> and compare
>> it with the sunset/sunrise from a map created with r.sunmask I see great
>> differences (up to 50 minutes).
>> It is not the timezone (which is set correctly) in r.sunmask.
>> The results from r.sunmask seem to be, according to other sources,
>> seem to be
>> right, but the results from r.sun are fare off.
>> Please give a suggestions or help!
>> Stefan
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Thanks for Your suggestion Stephen,
but I have to make "shadow" maps with r.sun and my problem is how to get
r.sun work within the correct sunrise/sunset timespan.
