[GRASS-user] Difference in sunset/sunrise time between r.sun
and r.sunmask
Stephen Sefick
sas0025 at auburn.edu
Tue Jan 3 11:48:16 EST 2012
Oh sorry, good luck.
On Mon 02 Jan 2012 10:46:44 AM EST, Büro Seling wrote:
> Am 02.01.2012 16:19, schrieb Stephen Sefick:
>> If you use R there is a sunrise.set function in the StreamMetabolism
>> package (shameless promotion). That may be helpful.
>> Stephen Sefick
>> On 01/02/2012 06:57 AM, Büro Seling wrote:
>>> Dear Group!
>>> Happy New Year @all!
>>> I work on a Linux GRASS 6.4.2 RC1. The area of interest is in
>>> central Europe and
>>> the projection is WGS84(EPSG:4326).
>>> When I use the r.sun module and let it show the sunset/sunrise time
>>> and compare
>>> it with the sunset/sunrise from a map created with r.sunmask I see
>>> great
>>> differences (up to 50 minutes).
>>> It is not the timezone (which is set correctly) in r.sunmask.
>>> The results from r.sunmask seem to be, according to other sources,
>>> seem to be
>>> right, but the results from r.sun are fare off.
>>> Please give a suggestions or help!
>>> Stefan
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Thanks for Your suggestion Stephen,
> but I have to make "shadow" maps with r.sun and my problem is how to
> get r.sun work within the correct sunrise/sunset timespan.
