[GRASS-user] Set default cell type to FCELL?
Rainer M Krug
r.m.krug at gmail.com
Tue Jan 10 07:23:30 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 10/01/12 13:17, Paulo van Breugel wrote:
> When you include in any one of your multiplication a number with
> at least one decimal your result should be a floating raster.
> Perhaps not
so
oldmap * 1
results in a raster of the same type as oldmap,
where
oldmap * 1.0
would result in a FCELL?
> as easy as what you are asking for, but it shouldn't be too error
> prone, should it?
In principal not - but I have to check the whole simulation.
Thanks,
Rainer
> Paulo
> On Tue, Jan 10, 2012 at 3:08 PM, Rainer M Krug <r.m.krug at gmail.com
> <mailto:r.m.krug at gmail.com>> wrote:
> On 10/01/12 12:50, Massimiliano Cannata wrote:
>> Hi, not sure to have understood what you want to do but maybe
>> using r.mapcalc functions: - double(x) --> convert x to
>> double-precision floating point - float(x) --> convert
>> x to single-precision floating point
> Sorry for not being more clear.
> What you suggest is exactly what I am doing - but it is very error
> prone, as I have to put this into numerous calculations (this is
> part of a simulation model).
> What I would like to do is tho change the default type from CELL
> to FCELL - i.e. whenever a new raster is created, it will *always*
> and *automatically* be saved in a FCELL raster, even if it only
> contains integer values, and not in a CELL raster.
> Cheers,
> Rainer
>> Maxi
>> On 01/10/2012 09:21 AM, Rainer M Krug wrote: -----BEGIN PGP
>> SIGNED MESSAGE----- Hash: SHA1
>> Hi
>> I have huge values in my raster cells and I am manually always
>> setting thrm to FCELL. Is there a possibility to instruct GRASS
>> to use FCELL (or DCELL) as a default instead of CELL?
>> Thanks
>> Rainer
>> - -- Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
>> (Conservation Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology Stellenbosch
>> University South Africa
>> Tel : +33 - (0)9 53 10 27 44 Cell: +33 - (0)6 85 62
>> 59 98 Fax : +33 - (0)9 58 10 27 44
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> email: Rainer at krugs.de <mailto:Rainer at krugs.de>
>> Skype: RMkrug
> _______________________________________________ grass-user mailing
> list grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Stellenbosch University
South Africa
Cell: +33 - (0)6 85 62 59 98
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk8MLcIACgkQoYgNqgF2egoSMQCePKxF92PrrqiAwqo2OLmlthyf
NkgAnjfdAf6dx1lz02Rnyu4g5gkPUZi3
=HmpG
-----END PGP SIGNATURE-----
