[GRASS-user] Set default cell type to FCELL?
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Jan 10 07:17:53 EST 2012
When you include in any one of your multiplication a number with at least
one decimal your result should be a floating raster. Perhaps not as easy as
what you are asking for, but it shouldn't be too error prone, should it?
Paulo
On Tue, Jan 10, 2012 at 3:08 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 10/01/12 12:50, Massimiliano Cannata wrote:
> > Hi, not sure to have understood what you want to do but maybe
> > using r.mapcalc functions: - double(x) --> convert x to
> > double-precision floating point - float(x) --> convert x
> > to single-precision floating point
> Sorry for not being more clear.
> What you suggest is exactly what I am doing - but it is very error
> prone, as I have to put this into numerous calculations (this is part
> of a simulation model).
> What I would like to do is tho change the default type from CELL to
> FCELL - i.e. whenever a new raster is created, it will *always* and
> *automatically* be saved in a FCELL raster, even if it only contains
> integer values, and not in a CELL raster.
> Cheers,
> Rainer
> > Maxi
> > On 01/10/2012 09:21 AM, Rainer M Krug wrote: -----BEGIN PGP SIGNED
> > MESSAGE----- Hash: SHA1
> > Hi
> > I have huge values in my raster cells and I am manually always
> > setting thrm to FCELL. Is there a possibility to instruct GRASS to
> > use FCELL (or DCELL) as a default instead of CELL?
> > Thanks
> > Rainer
> > - -- Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
> > (Conservation Biology, UCT), Dipl. Phys. (Germany)
> > Centre of Excellence for Invasion Biology Stellenbosch University
> > South Africa
> > Tel : +33 - (0)9 53 10 27 44 Cell: +33 - (0)6 85 62 59
> > 98 Fax : +33 - (0)9 58 10 27 44
> > Fax (D): +49 - (0)3 21 21 25 22 44
> > email: Rainer at krugs.de
> > Skype: RMkrug -----BEGIN PGP SIGNATURE----- Version: GnuPG
> > v1.4.11 (GNU/Linux) Comment: Using GnuPG with Mozilla -
> > http://enigmail.mozdev.org/
> > iEYEARECAAYFAk8LP5AACgkQoYgNqgF2egqIMwCfeWPRNyLlu9ZamOmLcECGoisV
> > 81cAn0TBNu2YW7ugZ2o5eq/9XW6lvyV9 =eGtL -----END PGP SIGNATURE-----
> >> _______________________________________________ grass-user
> >> mailing list grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> South Africa
> Cell: +33 - (0)6 85 62 59 98
> Skype: RMkrug
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk8MKiUACgkQoYgNqgF2egqmOQCfR0VP+5VYGRK0r6ePFxIZ+Oa1
> snQAnRLfyjq9JJFwZzAhDZuEoGA7x1s6
> =vCXE
> grass-user mailing list
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120110/e6b748a1/attachment.html
